Home Forums Products Rackmount H8000 FW – banks concept and use Reply To: H8000 FW – banks concept and use
#119714
IDeangelis
Hi Luca
you may want to check the User Manual about User Groups (=MIDI Maps). The H8000 uses such groups to define which presets you want to load via MIDI. A default factory User Group loads a number of presets. That is the reason for what you see there.
Criteria do not set MIDI usage of presets. They only serve for UI purposes.
best
I
