Home › Forums › Products › Stompboxes › One expression pedal for two units? (on A/B switch) › Reply To: One expression pedal for two units? (on A/B switch)
#119762
badmelonfarmer
    Hi cacibi,
    I bought a Mission Engineering SP-2 for this very reason.
    it has a toe switch like a Wah On/Off that allows you to switch between two "Channels" so you can plug in a PitchFactor and a ModFactor and switch between the two  by pressing down on the toe position.
    it also has a LED that changes colour to show you which channel you are using.
    Built like a tank too.
    Cheers
    BMF
