Home Forums Products Stompboxes Any way to prevent outgoing CC transmit to through port Reply To: Any way to prevent outgoing CC transmit to through port
#119795
MaxFX
That works but it also seems to block the Program Changes that are required to switch the amp channels.  Oh well, the amp maker has a revised midi chip that addresses this known issue but I was hoping for a workaround in the meantime.  I ordered the chip.
If I understand correctly I should be able to configure the OUTPUT to XMT instead of passing data through, turn "on" PGM XMT and set the XMT MAP to transmit program changes to the Brunetti .  I tried this and it didn't do anything.  I'm not sure what the 059 is listening for but it doesn't respond to the TimeFactors midi maps or Program Transmits in this configuration.  Otherwise I would just create TimeFactor presets that also switch amp channels.  I'm pretty sure this would work, in theory, hehehehe.
