Home › Forums › Products › Stompboxes › Transmit key signature via midi with pitch factor › Reply To: Transmit key signature via midi with pitch factor
January 15, 2010 at 4:23 pm
#119799
Not sure what you mean by "key signature" in this context.
If you mean the key setting of the Diatonic you could use that knob to send a CC if you were setting it manually, but this is probably not what you have in mind.
