Home › Forums › Products › Stompboxes › Using the Stompboxes with a Midi Foot Controller › Reply To: Using the Stompboxes with a Midi Foot Controller
February 23, 2010 at 7:09 pm
#120042
NicD
You can do that easily using about any midi controller.
All you have to do is set them to the same midi channel the footcontroller is sending program changes to (p.35 of the TF manual), then change the program change map (p.38 of the TF manual) on each stompbox to switch to the correct preset for each "global" (ie footcontroller) program.
I'm using a Boss FC-50 footcontroller to switch presets on both my TimeFactor and a Rocktron Piranha preamp, works absolutely fine.
Hope that helps,
Nic
