Home Forums Products Rackmount Weird Flangin background noise Reply To: Weird Flangin background noise
#120117
jklarsen
Hi and sorry for the lack of details.
-how did you connect the Eclipse to the FX Loop? Type of sockets and cables.
Jack plugs in/out of the amp and into in/out jacks on the eclipse
-is the fx loop a +4 dB line level or -10/-20dB instrument level type?
It can be set to both, but is set to -10db because otherwise it is too loud
-is the fx loop parallel or serial?
Parallel
-which preset is giving you the problem? You must specify name and number.
Actually all the presets i have tried gives me the problem, it also happens when the unit is bypassed…..
But not when the fx loop is de-activated on the amp.
-is there anything else connected to this amp, other than your guitar and Eclipse?
It is straight forward, gtr into amp, amps fx loop into exclipse. I have used the same setup
for years, but i have only noticed the flangin noise after updating to 4.01.
The flangin noise dissapears when the dry/wet is set to 0.
I hope the clarifies it a bit.
Best…Jan
