Home › Forums › Products › Rackmount › Levels increased with 5.5 beta › Reply To: Levels increased with 5.5 beta
        March 31, 2010 at 12:33 pm
        #120236
Digital signals hit a 0 dB threshold you can't go higher…or bad distortion is what you get.
Since you don't specify routing and used presets, here's what you can try:
-set dry/wet mix on 100%wet
-load the THRU preset in both DSPs
-try now…
how do you measure the signal level?
best
I
