Home Forums Products Rackmount Sample Rate Conversion for Axe FX inside Eclipse Reply To: Sample Rate Conversion for Axe FX inside Eclipse
#120652
    The Eclipse has Sample Rate Conversion on its digital inputs so you should be able to do what you want (why 88.2 ?). Some manual reading will be required – you should set the Eclipse clock to internal 88.2, then enable the SRC on the digital inputs.
