Home › Forums › Products › Stompboxes › Does the TimeFactor sum the inputs on mono output even when bypassed? › Reply To: Does the TimeFactor sum the inputs on mono output even when bypassed?
#122206
MarcoR
    I would like to know this too. Actually, I'm interested in left/right out of the timefactor into left/right  space then mono out space. The reason is to achieve series parallel path where I send a dry signal to space to be processed with reverb but the wet delay is summed in the output; the goal being not to apply reverb to the delay.
