Home › Forums › Products › Rackmount › Startup problem › Reply To: Startup problem
June 20, 2011 at 3:45 pm
#122318
Looks like you've cleared the problem, so hard to check into it. You may well have had a RAM corruption, which could have many symptoms.
Alternatively, loading the two presets at 96k may have briefly overloaded the unit (which is what the messages mean, although they could also have a hardware cause).
Hard to tell after the fact. If it happens again, contact support@eventide.com
