Home › Forums › Products › Stompboxes › PitchFactor Whammy MIDI Problem › Reply To: PitchFactor Whammy MIDI Problem
August 16, 2011 at 3:21 pm
#122543
I believe this is a bug. The workaround is to just plug a "dummy" jack into the expression pedal input on the back. After you do this, you should be able to use expression pedal over MIDI in Pitchflex. This is the only algorithm this bug affects. Try this and let me know if it works.
Thanks,
Russ
