Home Forums Products Stompboxes Time Factor in Mesa Boogie Triple Rec Effects Loop – Please Help Reply To: Time Factor in Mesa Boogie Triple Rec Effects Loop – Please Help
#124152
Hi Thanks for response,
  Can mix the level of wet dry signal on mesa unlike peavey valve king (i used previously) so am guessing it series ?
I dont even understand the concept of a buffer ?
I dont think is the interaction with other pedals as  I said I've used on its own in effects loop and same tone suck voulme drop occurs even when the pedal is not switched on but effects loop is
I know the switched you are talking about on the back of the timefactor but am I right they only effect the the loop when the pedal is actually turned on ? this problem happens when I turn on the effects loop and haven't the timefactor turned on ?
