Home › Forums › Products › Stompboxes › Y cable to split EV5 expression pedal for MF and PF › Reply To: Y cable to split EV5 expression pedal for MF and PF
#124417
mc_deli
    I was thinking I would make a little "one-stereo-in-three-stereo-out" box for this, in case I need to use the EV5 with something else as well.
    (Actually I was thinking of also making the same splitter for the FS 3X 3 button footswitch I have and mounting it in the same box… but I digress)
    If I was making a splitter for a pedal power cable I understand how lifting the ground on one of the connectors will eliminate ground loops, but with a passive balanced splitter like this are you hinting that there is some thing I should do to eliminate ground loops?
    Thanks for the reply by the way
