Home Forums Products Stompboxes after update to ios7 my H9 is unrecognized Reply To: after update to ios7 my H9 is unrecognized
#124841
gkellum
Sorry to hear you're having problems after updating.  I'm not sure what "my H9 is unrecognized means".  When you go into Bluetooth settings, can you pair with the H9 via Bluetooth?  If your H9 is not showing up there, toggle Bluetooth on and off on the H9 by pressing the X, Y, and Z switches simultaneously twice (the blue led in the upper right hand of the H9 will show if it's on) and if it still doesn't show up, reset your Bluetooth settings.  If this is not the problem you're having, please describe in more detail the problem.
