Home › Forums › Products › Stompboxes › Modfactor LFO problem with midi clock sync › Reply To: Modfactor LFO problem with midi clock sync
April 26, 2014 at 9:09 pm
#125785
Thanks for your answer.
I know that function, but in my case is not functional
In my band, I work with cubase SX and need to sync all my ModFactor effects and that the LFO will exact sync with the click of Cubase. I need the LFO works perfectly synchronized with the tempo of Cubase. I use tremolo much, and if the LFO will not exact, it is very audible.
Is there any other alternative for this problem? Is there any way to set the LFO so that it does not restart each time you change preset?
Thanks again and sory my bad english.
