Home Forums Products Stompboxes Peak Problem in my effect loop Reply To: Peak Problem in my effect loop
#126366
gkellum
Gabriel_Fusion:
Oh and i did try to lower the db output without any good result.
You mean the preset output gain in the first stompbox in the chain?  Also, when you say that the peak LED is on all of the time, do you mean on the first stompbox in the chain? Are you hearing clipping?
