Home Forums Products Plug-Ins blackhole not loading Reply To: blackhole not loading
#127058
DGillespie
    Hi obiwan,
    It's important to make sure that you only install the 32 bit plug-in to your 32 bit plug-in folder, and not the 64 bit.  If both plug-ins are in there it may cause confusion in Ableton and refuse to load.  If you check the folder that Ableton is looking in, do you see only one copy of the UltraChannel.dll?
    Thanks,
    Dan
