Home › Forums › Products › Rackmount › Problem with Behringer FCB1010 MIDI foot controller › Reply To: Problem with Behringer FCB1010 MIDI foot controller
March 21, 2008 at 3:13 pm
#128308
J20056
The error message is "MIDI : Cannot load setup 0"
My H7600 MIDI setyp is as follows:
global configure page
MIDI: enabled
serial: disabled
MIDI map: Group2 U
sequence out: off
system exclusive: on
device ID: 1
MIDI setup page
MIDI: enabled
base channel: 3
omni mode: off
note mode: mono
pressure: channel
pitch bend: 0
sysex speed: 10
midiclk out: off
MIDI group setup page
mode: MIDI single
channel: base + 0
con: 70
operation: normal
group size: 0
active con: 0
Please let me know if you see anyhting funky.
Also, would it help if I email you the sysex file?
