March 25, 2008 at 7:23 am
#128321
If you need to remote the unit BYPASS, the same as the Bypass key function, you don't need Externals; the reason is that BYPASS as a dedicated patching area.
Press SETUP > EXTERNALS several times until you see BYPASS on the left side of the display. Press its key. Here is where you will patch a footswitch connected to Eclipse Pedal 1/2 to the Bypass function. On the second screen it also offers a TRIGMODE function which allows software configuration of the switch as momentary (unlatched) or Off/On (latched).
best
I
