Home › Forums › Products › Stompboxes › Modfactor issue – FX Loop phasing issue with Trem/Pan › Reply To: Modfactor issue – FX Loop phasing issue with Trem/Pan
May 14, 2008 at 6:41 pm
#128638
Hi Jeff,
The problem is indeed the parallel effects loop with tremolo. I know some FUCHS amps have switchable series/parallel loops. If you put it in series the problem should go away.
Let me know if this helps.
Dan
