Home › Forums › Products › Rackmount › Saving Wet/Dry mix in Orville Presets › Reply To: Saving Wet/Dry mix in Orville Presets
June 4, 2008 at 7:53 pm
#128702
krcassid
One more pass at this since it appears it will dog me w/ 8000 upgrade as well:
Orville manual talks about "saving setups" which include most parameters of both DSPs and I/O. This, if it were recallable via Midi, would be the ideal solution. Even for studio work it would be good w/o midi. If I can recall a setup of both DSPs w/ all I/O and wet/dry parameters, this would be perfect.
Thoughts?
Is there a limitation on how many setups you can store (or memory issues?)
Can setups be recalled live via midi CC?
Thx for all your help!
