Home Forums Products Rackmount Eclipse V3.5 Block bypass externals – problems Reply To: Eclipse V3.5 Block bypass externals – problems
#128745
Mr_Clean
Another find: Seems the problems start when I switch to a program that has only one block rather than two. So if I select Band Taps & select Diamond Rain (or something with 2 blocks) the Eclipse does not consistently go into the correct bypass status based on the Ground Control.
