Home Forums Products Rackmount Eclipse V3.5 Block bypass externals – problems Reply To: Eclipse V3.5 Block bypass externals – problems
#128759
Mr_Clean
Nick, another thought. What if the A& B bypass was engaged via the foot control inputs on the back – not MIDI. It would require the purchase of a MIDI switcher that sends latch type switches, but it would avoid MIDI altogether for this function. Do you think the Eclipse would respond consistently in this way? cheers Mike
