Home Forums Products Rackmount Modulation pb with 3.5 Reply To: Modulation pb with 3.5
#128814
IDeangelis
 Hi Vincent
I did my tests on BandDelays, patching LFO#1 to Freq1 , first delay filter. I used your values, setting freq. to 500Hz, then patching it to the lfo with scaling +1500 Hz…it correctly sweeps between 500 and 2000 Hz. Stored the preset and reloaded…works fine. I did UPDATE  it on a second try and Freq 1 is now swept between 0 and 1500Hz as you reported. Looks like the Mod Block resets the min value…a bug (possibly).
On to engineers!
thanks for reporting this!
At the moment the work_around would be recreating the mod patching in the new preset and store it.
best
I
