Home Forums Products Rackmount MIDI Map… additional Reply To: MIDI Map… additional
#128922
Sounds reasonable – note that the Usergroups you see after SETUP are the same things as the Usergroup MIDImaps.
You may want to check that you have the latest manual – these are available on the H8000 support section of the Web Site.
