Home › Forums › Products › Stompboxes › tf / md midi together? › Reply To: tf / md midi together?
September 23, 2008 at 6:18 pm
#129033
Yes that would be another current disadvantage; presently you can only call up a preset as "Active" via MIDI. This is something that other users have pointed out and we are addressing this in the next software update.
A current workaround would be as you mentioned, to save a preset as "dry, " ie with all knobs fully counter-clockwise (on ModFactor use the Tremelo Effect.)
Another thing to consider is that you can use one aux switch with a "Y" adapter to bypass both stompboxes at once.
