Home › Forums › Products › Vsig and Preset Development › midisport (8×8) compatibility? › Reply To: midisport (8×8) compatibility?
December 1, 2008 at 1:07 pm
#129177
IDeangelis
Hi Paje
when a MIDI interface shows up in the fields I mentioned, it should work. There is pretty much nothing else regarding configuration needed in Vsig. MIDI devices should be properly installed and configured on the computer (nice one, you have!).
Orville, as any other Vsig supported unit, simply needs to have MIDI: enabled, system exclusive : on and device ID: 1, under SETUP > MIDI tab. Both MIDI cables (IN/OUT) should be connected (handshaking).
best
I
