Home › Forums › Products › Rackmount › Problem with new fx block bypass parameters › Reply To: Problem with new fx block bypass parameters
January 20, 2009 at 6:50 am
#129300
Mr_Clean
See the following thread:
Eclipse V3.5 Block bypass externals – problems – http://forum.eventide.com/cs/forums/p/4867/20526.aspx#20526
The latest OS 3.51 seems to have fixed this problem for me. I use the ground Control with the Eclipse with Block A & B set to different cc's on the Ground Ctrl for random access. When I select a GC patch it selects the appropriate block (via a CC) as part of the program. cheers
