Home Forums Products Rackmount Question about routing vocals with H8000FW Reply To: Question about routing vocals with H8000FW
#129405
akjl4
I still am having no luck hearing the entire patch, 5314 4 detuners, all I am hearing is the first in and output from the dsp a. For instance I loaded the routing preset analog a-b since I have my preamp connected to analog 1, then I changed dsp a's inputs to 1- 4 to analog 1 in hopes of using the 4 detuners patch 5314 but I still only hear input 1 not 1- 4.
Am I setting it up correctly?
I have the eventide connect to my computer thru firewire.
