Home Forums Products Rackmount Sampling Rates and Buffer Size Reply To: Sampling Rates and Buffer Size
#129421
ThreeFingersOfLove
Hi Nick,
here's the information I ommited:
Software version: H-8000FW: 5.3, Dice: PAL Version: 3.2.0.1556 – driver version: 3.2.0 build 1556
Sample rate: any sample rate causes clicks
Sync source: internal
Operation mode: Safe Mode Level 1
Buffer size: 576
WDM = Enabled
Sample rate change restriction = Allow ASIO clients only
Finally, I don't have any values for latency, on the "Recommended WDM Operation Mode" it says "Error" 🙁
Best regards,
Yannis.
