Home Forums Products Rackmount Crashed, stuck, and out of luck. Reply To: Crashed, stuck, and out of luck.
#129546
IDeangelis
I would work at 48KHz to get all presets working. If you have tried connecting the digi 02 digitally to Eclipse and then its signal comes back to the digi in digital format, you get a loop and sync issues are possible. Since you seem to have several f?dital units in your setup, a W.C. dedicated unit is what you may consider to get the best sync for all units there.
The way you are trying to clock the rig, S/Pdif (not the best one!) and W.C. together is definitely not recommended.
BTW use the XLRs I/Os on Eclipse as those are the only ones dedicated to line levels signals (+4 dB), being what you provide to the unit in your system.
Question… why a compressor in front of an fx processor?
best
I
