Home Forums Products Stompboxes TIMEFACTOR + POWER SUPPLY Reply To: TIMEFACTOR + POWER SUPPLY
#129707
ralfl
I use my (Dutch) Burkey Flatliner to power both the Time and Mod – with no noise at all.
Here's how: I run each pedal off three of the 9 VDC/200 mA isolated outlets in parallel – which gives the pedals 600 mA each, and which is clearly enough. Despite ten other pedals on the board there isn't even a hint of hiss or ground hum.
Seems like "isolated ground" should be the mantra here.
