Home › Forums › Products › Rackmount › H7600 Preamp presets problems. › Reply To: H7600 Preamp presets problems.
June 4, 2009 at 7:20 pm
#129783
IDeangelis
Morten
hard to say what's the problem, if any.
You should replace the battery if that helps.
Also I would try to reinitialize the unit with the 8 key and check if the default settings work fine.
all the best
I
