Home Forums Products Rackmount H8000FW problem: DSP code 2001 Reply To: H8000FW problem: DSP code 2001
#130313
    Neither the choice of 110/220  nor the sinewave quality are the issue – it is the stability of the voltage that counts – any major dropouts could cause connected equipment (not just the H8000) to reset or lockup.
    You do need to ground the unit properly for safety and reliability reasons. If you are having ground loop issues, use XLR in and out, but drop the screen connection, usually on the inputs.
