Home Forums Products Rackmount H 8000FW OS 5.3 upgrade problem Reply To: H 8000FW OS 5.3 upgrade problem
#130835
IDeangelis
John
it's amazing what people say! We have adviced and described what type of serial cable should be used. The reason is there are different types with different wiring, like null_modem ones. We use the regular type where each number of pin is wired to the corresponding numbered one on the other side of the cable. So there is no Eventide with wrong numbering of the pins, just people who are using wrong serial cables.
You may want to check the technote "Troubleshoting problems with Oupdate" at the bottom page here:
http://www.eventide.com/AudioDivision/Support/Harmonizers%20and%20Rack%20Products/H8000%20Series.aspx#documentation
There is also a detailed description on how to use the Keyspan adapter in the Harmonizer folder of the forums.
all the best
I
