Home › Forums › Products › Stompboxes › Set Tap Tempo with External Pedal › Reply To: Set Tap Tempo with External Pedal
January 12, 2010 at 12:05 am
#130896
flyingv2010:
the footswitch didn't take over taptempo, but activate and bypass the preset
It is possible to have multiple things connected to a footswitch – if you look at the other settings, you'll probably see that BYPASS is connected to TIP as well – this would explain what you see. The solution will be apparent.
flyingv2010:
is it only possible to tap the tempo in play-mode or is it also possible in the bank-mode
If you use the external footswitch, it will be active in either mode.
