Home › Forums › Products › Rackmount › H8000FW Ableton routing › Reply To: H8000FW Ableton routing
nickrose:
MicrokevH8000:
Ah, I just checked and it was also the oscillator…
As I thought. Sounds like you can send from the H8000 but not receive. Is this your understanding?
You're correct about that. But there's an update below…
I'm sorry, you're right, I skipped over answering these. My apologies.
Is there anything visible on the H8000 meters ?
Have you tried setting the H8000 for factory defaults ?
Are you using the latest H8000 software and drivers (from Web Site) ?
I have gotten lights on the H8000 meters when sending audio to it.
I'm not sure how to set the H8000 for factory defaults.
I am using the latest drivers from the website, but don't know how to check if I've got the latest H8000 software.
**A new development, I am now able to send and receive audio via the H8000. A major hurdle crossed, and I thank you for that.
The next hurdle is how to send signal from the computer through the H8000 <<without>> using the effects. I've set DSP B to Thru, but I don't exactly understand how to separate the routing to DSP B and DSP A. (This was why I planned to use it in conjunction with the Motu 828).
