Home › Forums › Products › Stompboxes › Time Factor Tape Delay Setting – Saturation Control › Reply To: Time Factor Tape Delay Setting – Saturation Control
January 19, 2010 at 5:35 pm
#130964
Hi Guys,
What Russ says is true. I'll also add that if you're
using TF in the loop, all amp loops are not at the same level. In some
instances it might be necessary to run the TF in Gutiar/Instrument mode
even in the loop. This will increase the level in the pedal and give
you more saturation in the TapeEcho.
Dan
