Home › Forums › Products › Rackmount › Ext. midi controller to adjust effect parameters on Eclipse › Reply To: Ext. midi controller to adjust effect parameters on Eclipse
January 20, 2010 at 4:24 pm
#130981
IDeangelis
ok…now we rock!
You may need to adjust the scaling of the parameter in regards to the MIDI CC. Try adjusting SCALE in the patching area, second screen. The scale value should reflect the same number of the parameter's steps number you want to control…so first count how many RhytSubDivs are in there….
This should help
I
