Home Forums Products Stompboxes Any way to prevent outgoing CC transmit to through port Reply To: Any way to prevent outgoing CC transmit to through port
#131132
MaxFX:
Is there any way to filter out CC messages on the through port while allowing PC messages to pass?
Sorry, no. You either have THRU or not-THRU.
MaxFX:
What kind of cables will I need to use a non MIDI expression pedal with the TimeFactor (stereo or mono)?
You can use a mono or stereo cable (it only uses tip and sleeve).
MaxFX:
Also, is it possible to use the aux port on the TimeFactor with a second expression pedal
The aux port expects a switch – a pedal can act like a switch, but this is not very useful.
