Home › Forums › Products › Stompboxes › Help – Program Transmit not functioning! › Reply To: Help – Program Transmit not functioning!
January 5, 2011 at 5:00 pm
#132461
Thanks Nick! I get no response from the 'slave' (I want Timefactor to control ModFactor). All I want to do is load presets ala the Instructional Video. Do I need to go through the entire MIDI mapping process for each patch? I thought it was as simple as your video showed!
I tried different cables – including a brand new MIDI (Monstercable) – they are connected IN to OUT.
Did you see the settings that I posted in the post above yours? It details the MIDI settings – let me know if you need MORE info. Hopefully this helps! I'm a MIDI idiot, so any help would be greatly appreciated!
