Home › Forums › Products › Rackmount › Eclipse Volume Issues? › Reply To: Eclipse Volume Issues?
January 9, 2011 at 11:23 pm
#132494
Hi Bert,
I did manage to get some better results with this problem, as some of the effects i use in block A had the ability to raise the output level if I went deep into the parameters of the effect and edited the output levels. However, as the Eventide guys could not resolve this issue, I decided to buy a Timefactor pedal and added this after the Eclipse in the signal chain. An expensive add on really, but was the only practical way i could find sorry. Hope you have better luck :o)
