Home Forums Products Stompboxes pitchfactor and midi RCV CC for expression pedal problem Reply To: pitchfactor and midi RCV CC for expression pedal problem
#132820
6stringriffs
No. It does not!
I own this Hex and it is really useless not just for the eventide pedals. The potentiometer value, 250kohms is way too high. My pitchfactor expression input will only accept a small, small fraction of the pot's resistance. Meaning, a very slight movement of the pedal and I've gone through the entire range of the PF's parameter range. Need an expression pedal that's less than 25kohms.
