Home › Forums › Products › Stompboxes › Midi control of MF from TF › Reply To: Midi control of MF from TF
#133260
Why would you need to send CCs on different channels? I mean, I could easily be missing something here, but both the TF and MF can receive on the same channel, which would be necessary to use one CC switch as the "tap" destination for both devices. You would lose the ability to address each pedal individually, but that may not be necessary, depending on your needs.
