Home › Forums › Products › Stompboxes › Make Modfactor, Pitchfactor swith work like Space › Reply To: Make Modfactor, Pitchfactor swith work like Space
June 9, 2011 at 4:50 pm
#133501
achaput:
If you have Space and another Factor pedal you could have them select Presets on each other via MIDI. Then you have the choice of both interfaces at the same time.
The problem is, when changing presets on Space you have a ridiculous lag time that will ruin it for your other factor pedals.
