Home Forums Products Stompboxes Ultimate P/T/MFactor control with Musicomlab MKIII Reply To: Ultimate P/T/MFactor control with Musicomlab MKIII
#133597
badmelonfarmer
    Here you go,
    to be honest the easies way I found was to just get the equipment and play, if you come from an IT background then it is very easy to get going…. I am no expert! LOL
    PC = Program Changes …. preset changes
    CC = Continuous Controller Changes – things like Tap Tempo, preset bypass, tuner…things that are more global
    MIDI Channels = Assign 1 to each device, so Space might be 1, TimeFactor 2 andModFactor 3.
    You can then set your controller to say send PC 1 to MIDI Channel 1 this would set the Space to the Hall preset and leave the other in their present state.
    another button on your controller might send PC2 to MIDI Chanel 1 and PC5 to MIDI Channel 2… in this example it would change Space to Room and TimeFactor to 3:1 Guitars in Space.
    As I said I do not know the MIDI controller you are talking about, but that is the basic principal for the MIDI Controllers I have used with the Factor pedals
    Hope that helps.
