Home Forums Products Rackmount H8000FW routing limitations Reply To: H8000FW routing limitations
#133775
Gigantoad:
Can you explain the bolded part? I still don't see how to connect more DSP inputs
Any or all the DSP inputs can be connected to any of the Main-in outputs, or any of the DSP outputs. Can you be more specific – exactly what inputs are you unable to connect to what outputs ? As far as I know, the routing program is correct – anything it says you can't do, you can't do.
Gigantoad:
Also you wrote that FW in can be connected directly fo FW out, which would really help, but the routing utility doesn't allow that.
Sorry – you are right here – I was wrong. There is some hardware restriction (which I never understand) that stops you from doing this.
