Home › Forums › Products › Stompboxes › Phase issues with Eventide Space during patch changes › Reply To: Phase issues with Eventide Space during patch changes
September 4, 2012 at 8:18 pm
#134824
Hi Dan,
To follow up, I had Spillover "on", and turned it off to test per your recommendation. Unfortunately that did not solve the issue. I also tried switiching between DSP+FX, DSP, and Relay settings, and unfortuantely that did not solve the issue either.
I think I got what you mentioned in your last response, I turned KillDry off to see if that sound is the same, and confirmed that phasing sound is the same. Based on what I heard, it really sounds like a dry signal is coming out of the space durring the 2 second patch over change.
What can I do to fix it? Thanks
