Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
#135369
beedoola
    brock:
    SplicerGlitch
    Mix = WET:100
    Pitch Mix = A10+B10
    Pitch A = ArpA: OFF
    Pitch B = ArpB: OFF
    Delay A = GrvA: A05
    Delay B = GrvB: B12
    (encoder) = PEGGIATR / TMP ON
    Depth / Key = ATK:  0
    Speed / Scale = LN: 1/16
    Xnob = FXA: GLT2
    Ynob = FXB: GLT1
    (EXP PED Heel) = ATK:  5
    (EXP PED Toe) = ATK: -5
    Two steady groove patterns add glitching accents to create a more complex rhythmic effect.  Interaction among the five glitch patterns, the 20 groove patterns, separate A & B channels, and the Depth / Key attack control varies the effect from barely noticeable to an overwhelming glitch-fest.
    Expression Pedal:
    Backing off the pedal brings the glitches to the forefront, with pushing forward smears the groove patterns and glitch steps together.
    Cool. I played around and change the following:
    Delay B – B10
    Attack – +3
    X/Y Knobs – Glitch 1
