Home › Forums › Products › Stompboxes › H9 Sync with Logic X Midi clock › Reply To: H9 Sync with Logic X Midi clock
#138586
    soleux:
    I set the pedal to be the slave
    By this I assume you mean set [CLK IN] (MIDI Input Clock) to ON. Does the display flash when you do this ? If so, it is not seeing the MIDI clock.
    soleux:
    the pedal dont follow the song tempo
    In what way ? Does it show BPM values if you change the master tempo ?
    If it does not show the BPM values, the problem is with your DAW.
